Old 07-31-2005, 03:51 PM
LeeParsons
Send a message via ICQ to LeeParsons
Default Copy Chrome rust showing through
I recently plated some bolts for a license plate bracket with Copy Chrome. It has been about a week and one little rain storm and they are showing rust. Is this a charactoristic of Copy Chrome? Is it not durable enought for exposure to the elements? Did I mess up (probably)?
I did 4 on the front plate and 2 on the rear, only front is showing rust. Plared a couple of items under the hood (wing nuts and the like) and it is doing fine.
Any tips, trick or suggestions?
Thanks,
Lee
Old 07-31-2005, 03:55 PM
charlton
I'm not the expert friend but I'm thinking it's said that Chrome is extremely pourous and therefore you have to nickel plate underneath it to prevent rust?
But then you probably did that I would suspect?
Old 08-07-2005, 09:49 AM
Moderator
What method did you use to prepare the part prior to plating? Also, did you use a copper plate before the copy chrome? For corrosion resilience I'd recommend a copper pre-plate before the final finish with copy chrome.
If there were voids created by small spots of oxidation or a microscopic film of grease, you may have a porous plate. Copy chrome isn't quite as resilient to the elements as real triple chrome, but it is significantly more resilient than what you are describing.
Ken
Old 08-19-2005, 01:14 PM
jimcarry's Avatar
jimcarry is on a distinguished road
Send a message via Yahoo to jimcarry
Default Re: Copy Chrome rust showing through
Thanks,
Lee
What time frame did you use for plating these bolts it possible that they were not plated long enough to achieve maximum thickness. Because copy chrome is a cobalt nickel solution I don’t think adding nickel to the plated object will make much of a deference . You may try extending the time in your sp de greaser also you should use a protectant such as zoop seal .
triple chrome vs. nickel/chrome vs. copy chrome spectraflamed Electroplating Questions 4 01-21-2007 10:07 AM
copy chrome vs triple chrome plating splbnd27 Electroplating Questions 18 06-21-2006 07:35 AM
Copy chrome and resistance to rust, tarnish, dulling? phunkmastakrez Copy Chrome Kit Customers Only 6 08-25-2005 09:13 AM
Copy Chrome Start-up Elitefisherman Electroplating Questions 10 04-18-2004 04:24 AM
Copy Chrome Questions junodale Electroplating Questions 13 03-17-2004 11:15 AM
