Originally Posted by
jimcarry
The pnp is not going to work over silvaspary . The silvaspray has an amount of silver particles in it and makes for a rough surface . Another way would be the Silver Nitrate Technique.
This is an immersion process .
Make up of the solution
• 1/4oz Silver Nitrate- available at photography supply store .
• 5oz rubbing alcohol- available at drug stores .
• 5 fl oz distilled water
dip the part in the solution and allow to dry . The silver nitrate now need to be conver ted to silver sulfide to make it a conductive surface .
Place about 2 fl oz of Caswells Bronzer solution in to a glass vessel .
Hang the part on a thread into the container .
In a well ventilated area pour 1 fl oz of battery acid into the Bronzer solution .
Immediately caver the container. Noxious fumes are emitted .
The fumes will convert the coating to a conductive surface . After 5 minn remove the item and proceed to plating with copper .
