+ Reply to Thread
Results 1 to 3 of 3
Thread: Plating Problem grey finish from chrome plating
  1. #1
    Default Plating Problem grey finish from chrome plating
    Ok here goes my first question, I have the 3.5 gal triple plate chrome kit. I plated yesterday for my first time! I was able to plate a very good nickel plate onto 1/2 copper tubes, actually this went pretty easy for me so I moved to copper, which was actully prettty good, i got the pink salmon color. At that time I tried a plain copper tube into the chrome, results were fine for not having any nickel on the tube. the chrome plating was reflective but not as shiney as it could be with the nickel underneath. He is where the question comes, I started the triple plate process on my first copper tube for my first complete process. With saying that, the copper and nickel came out just as decribsed above. The problem was when i tried to plate the chrome. I had correct amp 21 sq inches = 21 amps ( I had 21.3 amps) temperature was 113 respectfully, the tube stayed in the bath for 3 mins, when I removed the tube it was a milky grey color, I was just wondering what I did wrong? Should Chrome plating come out shiney? I did rinse, polish ,degrease, and water break after each stage. It just sucks to have a beatiful nickel shiney plate an ruin it... any help would be appericated!
    Share with Facebook
  2. #2
    Join Date
    Dec 2003
    Posts
    201
    If your chrome is a grey that usually means you burned it. It might buff out but if it doesn't strip the chrome off using 50/50 muratic/water, Activate the nickle in 10 to 20% sulfuric and chrome plate it again. Go over your surface area calcs and make sure they are right. If that is OK, then you may need to put robbers near the high current density areas (edges and high spots). One other thing, let the part sit dead (no current) in the chrome for a minute or two before applying power. Hope this helps.
    Share with Facebook
  3. #3
    Join Date
    Jun 2005
    Location
    beaumont misssissippi
    Posts
    309
    When I plate in the chrome tank I like to look at my volts instead of the amps, just a little trick I learned from a plater. My 300 amp rect. has a 8 volt meter, I take the the volts to about 7.5 for (5) sec. and then drop down to 5.5 for 1 min. and if the parts are small I hang a dumy piece on the rack to take some of the current. The reason for going to 7.5 for 5 sec. is to make sure the whole piece gets covered, because the first 5 sec. is when it gets its plating, the last few sec. is just plating over what you plated in the first 5 sec. of plating.
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. copy chrome vs triple chrome plating
    By splbnd27 in forum Electroplating Questions
    Last Post: 06-21-2006, 07:35 AM
  2. Plating Guitar Tremolo w/ Smoked Chrome (newbie)
    By taorama in forum Plating Pot Metal
    Last Post: 09-07-2005, 08:12 AM
  3. Wanted: Chrome plating in Bay Area (North Cal)
    By olaf_sc in forum Services Offered/Wanted
    Last Post: 11-19-2003, 11:22 AM
  4. Plating Chrome over Brass
    By mojobari in forum Electroplating Questions
    Last Post: 10-29-2002, 03:28 PM
  5. Repairing rusted chrome plating
    By Angel in forum Electroplating Questions
    Last Post: 04-19-2002, 10:13 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
