I want to plate some putter heads with a black shiny finish (black nickel?) I am also a COMPLETE novice to plating, so forgive my newbie questions.
From what I be able to research on the Web, plating nickel to die case zinc is a pain compared to plating to brass or steel. True? I would like to use the simplest electroless process if possible. Next question: If I hand-stamp a piece, should I do it before plating or after? Also a quick question about paint. If a piece is nickel plated, can parts of the piece be painted. I'm speaking about the sight dots and lines on a putter. Thanks, Brad |
We don't sell/know about black nickel, but we can advice for regular nickel. The process is likely similar.
You'll want to strike the die-cast first with either Flash Copper http://www.caswellplating.com/flashcopper.html or Pot Metal Primer (Electroless) http://www.caswellplating.com/alzinc.htm After priming, plate with the regular electroless nickel kit http://www.caswellplating.com/electroless.htm Hand stamp before plating to avoid fracturing the plate. Sure - you can paint over it.
| Gold Plating and Nickel plating | tzmandevil | Electroplating Questions | 2 | 09-16-2005 09:11 AM |
| Nickel bath inexplicably quits plating | jackf | Electroplating Questions | 5 | 01-25-2005 09:55 PM |
| plating trophy horse heads | Sherry | Services Offered/Wanted | 1 | 05-06-2004 03:58 AM |
| plating and size power? | chromo | Electroplating Questions | 7 | 01-18-2003 02:52 AM |
| Beginner Plating | GolfNut | Electroplating Questions | 2 | 05-17-2002 09:09 PM |
