Hello guys,
When doing the finishing copy chrome plating I know I use 2 nickle anodes + But is the - cathode a nickel piece as well or a copper piece attached to the product? Thanks P.S. no laughing I am a newbie |
The cathode (negative connection from the power supply) connects to the part you will be plating (use a short piece of copper wire to hang the part from and clip the negative lead to the copper wire).
The Anode (positive connection from the power supply) connects to the metal "Anode" that will transfer the metal to the part being plated (in your case, the (2) nickel sheets). so...... Clip the negative lead to a short piece of copper wire and hang the part being plated on this copper wire (you don't want your power supply leads getting wet with solutions). Clip the positive lead to the nickel anode sheets, (1 each) on either side of the tank. Keep the anodes at least 3" away from the part being plated. Lot's of air bubbles for agatation. Adjust the current to 65 to 100 milliamps per square inch of surface area of the part and plate the part for at least 1/2 hour. DON'T take the part out to look at it until the plating cycle (1/2 hour) is done, otherwise the plating will peel off. Ok, I can tell you already have more questions. E-mail me thru my profile for fool proof "step by step" instructions. (I made these up to assist members of the Caswell board.) George W. |
| using aluminum as a cathode | scocklin | Anodizing Questions | 19 | 03-31-2007 01:18 AM |
| Cathode size | R-Wells | Anodizing Questions | 7 | 04-22-2006 07:18 PM |
| Type III (hard coating)? | xtal01 | Anodizing Questions | 5 | 01-12-2005 12:05 AM |
| work area vs. cathode area | elton10 | Anodizing Questions | 4 | 03-25-2004 10:59 PM |
| How do I Hardcoat Anodize (Type III)? | 00_buckshot | Anodizing Questions | 2 | 09-09-2003 02:10 AM |
