N e one out there have a set up using the 12v deep cycle with the nichrome wires. Been doing some research on it, seems easy enough to get a decent amounts of amps from the set up, i was just concerned with the heat that will result when running 2,3,4,....wires. The example on the manual goes up to a 50amp combinations, i just wanna know if any one experimented with tryin go to higher.
In the manual it said that the wires can run as hot a 800 deg. After talkin to tech for the nichrome i was told that the 18gage used has a melting temp of 2200F so there is room to increase alittle. But this may at like a big heater since i am setting this up indoors. I guess i'll only need to use the really high amps when using the chrome tank;..so it wont be on long so i guess whatever temp it runs at will be ok. |
You seem to have figured it out. Yes, it will reach 800 degrees whilst operating, but each chrome job won't last for more than 5 minutes, so you won't roast.
It has also been suggested to immerse the entire wire loom in a water tank, but i don't really think that is necessary.
| Cheap powdercoating Heater/chroming power supply question | dagobert | Powder Coating Questions | 4 | 06-07-2004 03:47 PM |
| cheap powdercoating heater/chrome power supply question | dagobert | Electroplating Questions | 0 | 06-01-2004 11:59 AM |
| wire welder for power source | elboriqua | Electroplating Questions | 2 | 11-04-2003 06:25 PM |
| Anodizing Power Supply Q's | jnbsystems | Anodizing Questions | 7 | 10-02-2003 10:33 PM |
| Power source question | spectraflamed | Electroplating Questions | 2 | 04-07-2002 06:56 PM |
