To Copper or Not To Copper
Hello Everyone,
I'm restoring some antique bicycle parts, and I have a couple of questions:
Some of the parts I'm doing are going to have to have copper to fill pits in them.
Some of the parts I can get the steel clean enough to get a nice finish, I'm using electrolic nickel, plating with current.
Do I need to copper all the parts, even the ones I could plate directly on?
Is there a difference in the color of the finish if I don't copper?
Does the copper help with rust or corrosion prevention? IE would the nickel over steel rust faster than the nickel over copper?
Obviously it's quite a bit easier to plate directly to the stell, but I want to get this right and have uniform color & finish.
Thanks!
Dave
