Old 09-23-2005, 03:21 PM
hefrod
Default glass bead have zinc?
Hey guys I have a a question about my sand blaster.
I use glass beads in it, when I blast a part it has a somewhat glossy or zinc color to it. Will this glass bead cause any problems while Copy Chrome plating?
The copper flash goes on beautifully. I SP degrease and pickle after blasting.
Thanks
Old 09-23-2005, 05:32 PM
mcaswell's Avatar
Caswell Inc Founder
Default Re: glass bead have zinc?
I think what you see is the polishing action of the beads, not any zinc.
Because they are round, they glide along the surface, burnishing it.
Aluminum oxide, however, has irregular sharp angular shapes, which dig into the surface. The particles tend to explode, when aimed at 90 degrees, and it is this abrasive explosion which scratches up the surface, and removes rust more effectively.
So, use glass beads to polish/burnish, use Al oxide to remove rust/paint, and to rough up a surfaceto accept paint.
Plating prefers a smooth polished/burnished surface.
Have A Web Site?
Old 09-23-2005, 08:15 PM
jimcarry's Avatar
jimcarry is on a distinguished road
Send a message via Yahoo to jimcarry
Thanks
also if you havent you can read my article on soda blasting
here What to replace sand with (blasting) ? and more info here What blasting media?
Jim Eaton
