Old 10-23-2002, 09:43 PM
guschennells
Default silver plating
Hi Caswell, I am having success silver plating harmonicas! A few questions: What is the percipitant forming on the bottom of the solution? Is it best to leave it be or stir it up. Should the solution ever be filtered? What is the chemical composition of the solution? Is it dangerous to get a little on you fingers? Is sterling silver ok as an anode or is pure silver best? I seem to have best results plating in stages, polishing a little between dunks. Is this typical? Thanks again. Gus
I'm into modifying and inventing
Old 10-24-2002, 12:27 AM
mcaswell's Avatar
Caswell Inc Founder
This is normal. If you heat the solution and stir, it should dissolve back in.
It might need to be at some point, but only if the solution stops working or the results aren't as good as they were when the solution is new.
It's proprietary.
Not the silver solution, no.
Pure silver would be best. You can also use stainless steel, but this depletes the solution quickly.
Very typical, yes.
Have A Web Site?
Silver plating on top of a computer processor jungle Electroplating Questions 5 05-13-2004 09:22 PM
Silver plating agugliel75 Electroplating Questions 1 02-15-2004 04:35 AM
Silver plating and rapid tarnish rustydog Electroplating Questions 0 04-15-2003 02:43 AM
High quality silver plating needed. clovenguth Services Offered/Wanted 0 04-02-2003 01:58 PM
Silver Plating on Copper hparent Electroplating Questions 1 04-03-2002 05:16 PM
