I am plating a small (8" by 10") steel plate. It is already in good shape, with minor scratches. Can I use Flash Copper as a build-up coat to avoid the acid step? I will be putting nickel over the finished plate. Thank you!
Chris |
If you want to, you can polish the nickle some, to get out small scratches. But its best to polish the piece before you start plating, then put a light coat of flash copper and so on.
