Old 10-02-2005, 12:27 AM
promodvette is on a distinguished road
Default Nickel Plate Kit
I just got my electroless nickel plate kit and wondering if any of you pros have some tips that may help me out some. Will nickel cover solder? Can you solder to nickel? I am plating slot car chassis that some may be soldered together first but eventually will have to get soldered on. Any help would be appriciated. Thanks a lot in advance!
Old 10-02-2005, 02:53 AM
walker56 is on a distinguished road
Smile Re: Nickel Plate Kit
try brazing instead of solder for nickle plating........
Old 10-02-2005, 06:52 PM
Default Re: Nickel Plate Kit
So it wont stick or it will just is better with brazing?
Old 10-03-2005, 07:43 AM
jimcarry's Avatar
jimcarry is on a distinguished road
Send a message via Yahoo to jimcarry
It will stick as long as you are using a good silver solder
Jim Eaton
Old 10-07-2005, 09:59 PM
alright thanks! So I can plate over a good silver solder (prebuilt chassis) can I solder the plated parts togehter though? Use same solder or will any solder work?
Old 10-26-2005, 09:40 PM
Moderator
I have had pretty good luck with the nickel kit even with lead-tin solder as long as it is squeaky clean and oxide free. That's hard to achieve. You almost have to abrade the solder with Scotchbrite (followed by rinse) right before you put it in the tank. And acid pickling just oxidizes the solder, so I generally avoid that.
Silver solder is a safer bet, but you still have to keep it completely clean. Be sure to clean very thoroughly to remove every trace of flux. I recommend a pre-clean in 1:1 solution of Simple Green, cleaned ultrasonically, before proceeding to the final cleaning stage. This will clean up the flux substantially.
Ken
