Old 10-20-2005, 05:23 PM
platingjack is on a distinguished road
Default What outputs on power supply, for nickle plating kit?
I have yet to buy a nickle plating kit, but am thinking seriously about doing so. I noted that website says that you must supply your own power supply. What would outputs be, voltage/amperage, for nickly plating kit, 1.5 gallon? Anything else not included in Caswell small nickly plating kit?
Old 10-21-2005, 08:38 AM
jimcarry's Avatar
jimcarry is on a distinguished road
Send a message via Yahoo to jimcarry
Default Re: What outputs on power supply, for nickle plating kit?
I do not have a nickel plating kit but I have the copy chrome kit according to the Caswell
plating manual the Bright Nickel plates at 1 amp per 16 sq inches. there are also electro less nickel
plating kits available
Jim Eaton
Old 10-26-2005, 10:34 PM
Moderator
For the size nickel kit you're describing, you can probably do with a power supply that can output 5V and 5Amps. In actual use, it's unlikely for the voltage drop between the anode and object will ever exceed 2 Volts when the tank is operated around 120 degrees F.
The same thing goes for the flash copper solution, as long as you operate with copper anodes. If you use 316 stainless anodes, the voltage requirement shouldn't be higher than 3V.
You'll have to adjust the current (amperage) output in accordance with Jim's suggestion above, which will depend on the surface area you're plating.
Ken
Power Supply? machinist_1 Anodizing Questions 5 06-28-2005 11:58 AM
Power supply aalamo Electroplating Questions 5 11-24-2004 10:21 AM
New power supply? Tim Wiltse Anodizing Questions 7 10-23-2003 06:26 PM
Power Supply AzNGuNSmokE Anodizing Questions 4 09-22-2003 11:41 PM
Another about power supply rcull Electroplating Questions 1 01-31-2002 08:43 AM
