Raymond,
You're in good shape. It seems you could buy a small quantity of Fastgold and set up a subminiature tank plating operation for the gold. But please don't plate the gold directly over the brass since the brass will migrate through the gold and spot it.
You will need a nickel barrier. The good news is nickel over brass is easy. I'd recommend a small 1 gallon setup for the nickel. The hard part in plating is getting cleaning right. Buy yourself a small ultrasonic cleaner with a heater and do your cleaning with Caswell's SP degreaser. If you buff the parts or they are oily or greasy, do a pre-rinse in undiluted Simple Green first, in the ultrasonic. Please don't underestimate the importance of cleaning.
Between cleaning, pickling and plating steps do two separate rinses. On any rinse just prior to plating use distilled water.
The trick will be hanging your little parts in the plating tanks. To do 500 parts will take some time. But more sophisticated barrel plating approaches will be rather capital intensive so you will probably want to avoid them, unless you plan on doing this as a full time business. I have had some luck with little copper baskets fashioned out of copper screening inexpensively purchased at a hobby and craft store for the nickel step. But barrel plating with gold will cost you more since the gold will also plate out onto the barrel and you don't want to deplete the gold that way. That may require you to hang parts using wire; perhaps 5 at a time in the tank.
The rest of the plating process is described well in Caswell's manual. Plan on spending a few days reading and absorbing as much as you can about the processes. Then when the kits come you'll be better prepared to put it all together.
Again, the process will be clean >> rinse 2x >> pickle >> rinse 2x >> nickel >> rinse 2x >> gold >> rinse
Regards,
Ken
LinkBack URL
About LinkBacks
