Old 11-14-2005, 10:16 PM
mgcobra is on a distinguished road
Unhappy Acid copper not bond on flash copper help
When i sand the part the acid copper peels off .
Old 11-14-2005, 11:44 PM
smokeycity
Default Re: Acid copper not bond on flash copper help
what are you plating steel ,pot metal,brass we need info
Old 11-15-2005, 07:47 AM
jimcarry's Avatar
Moderator
jimcarry is on a distinguished road
Send a message via Yahoo to jimcarry
Smokeycity is right what substrate are you working with.
Then in between flash and acid copper steps are you polishing the piece or
just rinsing and moving to the acid copper. What grit paper are you using and
what kind of pressure this is a very light sanding process.
When asking a question or giving an answer we should all try to be as specific as possible
Jim Eaton
Old 10-08-2007, 06:38 PM
tcam2 is on a distinguished road
You might want to check the acid copper temperature. I had the same problem until I upped my solution temperature from 100 degrees to around 120.
Old 10-10-2007, 08:51 AM
KCV6's Avatar
The Flash copper is strongly alkaline. Make sure you thouroughly scrub and rinse the part before proceding to any other plating and always remember the steps of de-grease and activate if you have handled the parts in any way.
cheers
Flash Copper Frank39 Plating Pot Metal 8 06-04-2007 01:59 AM
flash copper fly Electroplating Questions 2 08-09-2005 12:09 AM
new flash&acid copper plating job/burn through jjones9620 Electroplating Questions 2 03-28-2004 09:31 PM
Flash copper vs acid copper for PCB Holes cdaw Electroplating Questions 3 02-28-2004 09:47 PM
Strike Copper or Acid Copper over Nickel? mdarr Electroplating Questions 2 07-13-2003 01:53 AM
Powered by vBulletin® Version 3.7.0
