Old 11-05-2002, 05:21 PM
shorton
Default Masking areas where no plate is wanted
Is there a way to "mask" an area so that it's not plated? I have a brass part that has some bare steel and some lead content metal that would need to be submerged but I don't want those reacting and being plated.
Thanks,
Scott
Old 11-05-2002, 10:53 PM
mcaswell's Avatar
Caswell Inc Founder
You can lacquer the part you don't want plated, then remove the lacquer with paint stripper after plating is complete.
Have A Web Site?
Old 11-05-2002, 11:12 PM
shorton
Just any 'ol spray laquer paint? Will enamel or polyurethane work too and not dissolve/contaminate plating solution?
Thanks,
Scott
Old 11-06-2002, 10:57 AM
48Buick
Default Masking of areas you dont want plated
Hi:
If you do use laquer, put a couple of coats on the part. If you only use one, you may grow little nodules where the electrolytic solution got through to the base metal.
48Buick
How to plate Nickel over old Nickel when steel shows through ASHENASH Electroplating Questions 3 04-22-2005 03:03 AM
How to NOT plate certain areas of part? remotestartdepot Electroplating Questions 4 03-01-2005 12:35 PM
Plug n Plate Gold over Sterling novenarosary Electroplating Questions 0 03-12-2004 10:00 PM
zinc plate nuts&bolts during restoration (quickly) mikeyr Electroplating Questions 0 02-17-2004 02:55 AM
Plug n Plate lphurley Electroplating Questions 3 09-23-2003 12:15 AM
