  #11 (permalink)
Old 11-21-2005, 01:33 PM
jimcarry's Avatar
jimcarry is on a distinguished road
Send a message via Yahoo to jimcarry
Default Re: Black soot on flash copper
Im just guessing your probably using a small kit 1 to 5 gal right? If this is the case the pump sent with the kit is sufficient. The manual says 1 amp per 10 to 15 sq” make sure you are with in this parameter. You should not have to pickle again just degrees and rinse also make sure your anodes
are not closer then 3" form the part
Jim Eaton
  #12 (permalink)
Old 11-21-2005, 05:10 PM
fly fly is offline
You said the part was mild steel, but are you sure, because it sounds like you might have aluminum or pot metal. From the steps that you took the steel should have plated, but it could be one little step that could throw us off. Do the magnet test.
If the part is steel blast the part, polish it to a shine, make sure you have rubber gloves on before you degrees, degrees, water test, solution (flash copper) at 120 temp., make sure you have bubbles, set machine at 2 volts, connect part to neg. wire before you go in solution, put part on bus bar, after 30 sec. go to the proper amps for one min., then check part. Then get back with us and let us know what happened.
  #13 (permalink)
Old 11-22-2005, 04:05 PM
jlmccuan
I have also used this kit for aluminum. Is it possible the zincate from the aluminum has contaminated the flash copper solution too much. SHould I dummy plate?
  #14 (permalink)
Old 11-22-2005, 05:43 PM
fly fly is offline
It would take alot of drag out from the zincate to contaminate the flash, and Yes I would plate a practice piece.
Acid copper not bond on flash copper help mgcobra Electroplating Questions 4 10-10-2007 09:51 AM
Flash Copper Frank39 Plating Pot Metal 8 06-04-2007 02:59 AM
flash copper on pot metal newview Electroplating Questions 2 11-18-2005 08:14 PM
flash copper fly Electroplating Questions 2 08-09-2005 01:09 AM
Flash copper vs acid copper for PCB Holes cdaw Electroplating Questions 3 02-28-2004 10:47 PM
