could you give us more information on the steps that you are taking from start to flash copper. What kind of metal are you working with? YOu might have too many amps or the part is not clean enough.
Also sounds somewhat like what happens when your power is reversed. Are you sure you have positive to anodes, negative to part?
Material is mild steel
Process is clean, degrease, rinse, zincate, rinse, #4 pickle, rinse, zincate again, rinse, #4 pickle, rinse, flash copper Part is a 2" round tube with a flange resulting in an area of 18sq in. I have checked the leads for polarity and it is correct unless someone switched the colored nuts. Thanks for all the help. |
Jim Eaton |
I zincated in the hopes of gaining some corrosion resistance.
If I reduce the amps, I get an orange soot. The surface has been prepared by glass bead blast and degrease. Definately passes water break. Part is 23 sq in. |
your amps should be around 1.5 the copper plate should come out pink salmon color
Jim Eaton |
I didn't see if you have the flash copper at operating temp. the temp. is around 120 degrees. THis will help if your not heating up the solution. Make sure you have large bubbles also this will help with plating too.
Is the filter pump not supplying enough agitation? Should I add an aerator as well?
Also, if I don't get the black soot, I get an orange coating that looks like powdercoat before it is baked. Basically, it looks and feels just like the black, only orange. I am getting some copperplate. When I glassbead the soot off I have a very faint copper color left. Also, another question re flash copper. If I try to replate a part already coated with flash copper do I need a pickle process, or just degrease and rinse? Thanks again for the help. |
| Acid copper not bond on flash copper help | mgcobra | Electroplating Questions | 4 | 10-10-2007 09:51 AM |
| Flash Copper | Frank39 | Plating Pot Metal | 8 | 06-04-2007 02:59 AM |
| flash copper on pot metal | newview | Electroplating Questions | 2 | 11-18-2005 08:14 PM |
| flash copper | fly | Electroplating Questions | 2 | 08-09-2005 01:09 AM |
| Flash copper vs acid copper for PCB Holes | cdaw | Electroplating Questions | 3 | 02-28-2004 10:47 PM |
