Old 11-19-2005, 05:10 PM
jlmccuan
Default Flash Copper on Lead Shot
Has anyone tried flash copper on lead shot? How did you set it up. Should the shot be stirred while plating? After immersion in #4 pickle, I have a dark gray cloud in my pickle tank. Will this settle out and still be able to use the pickle on steel? Thanks in advance for the avise.
Old 11-21-2005, 05:19 PM
fly fly is offline
Default Re: Flash Copper on Lead Shot
If you are still wondering, I have not tried this but you should be able to degrees the lead and go staight into the flash copper. Plate about a minute and then move parts after another minute and it should be ready for acid copper. THe clouds should settle and be ok but don't do it again because the acid eats the lead. If you don't mind me asking why would you plate lead shots?
Old 11-21-2005, 07:29 PM
mcaswell's Avatar
Caswell Inc Founder
This article might help you:
http://support.caswellplating.com/in...emid=8&nav=0,1
Have A Web Site?
Old 11-22-2005, 01:39 PM
jlmccuan
Lead shot is plated to provide a little more hardness, and roundness, but primarily lubricity to improve shotgun patterns at longer ranges.
Old 11-22-2005, 09:28 PM
jlmccuan
The article is good, at least I know it is possible. But, I need to figure out how to plate hundreds, if not thousands, of pieces of shot at once. Would plating the shot in a wire basket result in a solid lump? Also, will this contaminate my flash copper solution so badly that it would be useless for other metals? I know it can be done (copper plating lead shot), just not sure how they do it in mass scale or whether the method they use won't work for flash copper.
Old 11-22-2005, 11:50 PM
mcaswell's Avatar
Caswell Inc Founder
They use a barrel plating machine. Hunt around on the web for some suppliers. These are turn key systems, and they're usually very large and very expensive.
Have A Web Site?
Old 11-23-2005, 10:50 AM
jimmc is on a distinguished road
Thanks for the help.
Acid copper not bond on flash copper help mgcobra Electroplating Questions 4 10-10-2007 09:51 AM
Flash Copper Frank39 Plating Pot Metal 8 06-04-2007 02:59 AM
Flash Copper Problem gwjohnso Plating Pot Metal 12 02-28-2007 12:41 AM
flash copper fly Electroplating Questions 2 08-09-2005 01:09 AM
Flash copper vs acid copper for PCB Holes cdaw Electroplating Questions 3 02-28-2004 10:47 PM
