Old 12-05-2002, 07:51 PM
jime
Default % Sulfuric in Battery Acid?
I bought battery acid at an auto parts store to anodise with and the salesman said is was 100% sulfuric acid. It worked well at 50%. I bought some more later that was MUCH cheaper for a larger quantity at another store that didn't work so hot at 50%. Is it possible that it was diluted? Does anyone know what the dilution rate is for battery acid? Is there a better source for sulfuric?
Old 12-05-2002, 08:02 PM
jime
Default Should have...
...read other posts on the subject before, as it seems they answered most of my questions! Looks like i should use straight 'battery acid' and not dilute it. Is there a way to test the ratio in the solution?
Old 12-05-2002, 09:44 PM
mcaswell's Avatar
Caswell Inc Founder
You can test the specific gravity of the solution with a Hydrometer.
http://www.freasglass.com/battery.htm
Have A Web Site?
Old 01-26-2003, 07:35 AM
mcaswell's Avatar
Caswell Inc Founder
Buy Battery Acid from NAPA Auto Stores, product # 9002. It is a consistantly high quality product.
Specific gravity = 1.26
Pure sulfuric acid (reagent grade) is 98%
Battery acid is 1 part reagent grade to 2 parts distilled water.
Our instructions call for BATTERY ACID, which then has to be diluted.
The reason for this is that reagent grade is very difficult for the amateur plater to find, whereas battery acid is easy.
Have A Web Site?
Acid SniperSlayer Anodizing Questions 8 07-25-2005 09:59 PM
Where to buy sulfuric acid? jlister Anodizing Questions 2 11-14-2004 09:56 PM
where do i get battery acid for my copper kit plater12 Electroplating Questions 1 07-17-2004 08:49 PM
Acid for anodizing desert_roamer Anodizing Questions 5 07-25-2002 09:10 PM
Battery Acid. ketanjajal Electroplating Questions 1 03-05-2002 09:27 AM
