Old 03-16-2006, 01:41 PM
turboc is on a distinguished road
Default Nickel plate over color case hardened steel
Can nickel be direcetly plated over color case hardened steel? I would like to refinish a revolver in nickel, but the frame is case hardened. Thanks.
Old 03-16-2006, 02:22 PM
fly fly is offline
Default Re: Nickel plate over color case hardened steel
It might be possible, try dipping the part in 50/50 muratic acid and water for a few minutes and then rinse and go to the flash coppper...
I had trouble with tool steel, it would not ever plate...
Old 03-20-2006, 01:26 PM
JGray
I have nickel plated a number of shotgun receivers including three Krieghoff K-80's which are case hardened. No problem, just followed the instructions in the plating manual.
I plated 0.5 mils (30 minutes) and had very little problem getting pins and screws to go back in place.
Good luck.
J Gray
Filling pits in steel in preparation for nickel plating pastorclyde Electroplating Questions 2 07-13-2005 09:50 AM
How to plate Nickel over old Nickel when steel shows through ASHENASH Electroplating Questions 3 04-22-2005 03:03 AM
Fixing partial nickel plate sross Electroplating Questions 3 10-31-2004 07:13 PM
Electroless nickel on hardened steel lathe Electroplating Questions 0 09-07-2004 11:35 PM
Dealing with partially nickel plated steel AresP Electroplating Questions 3 08-19-2004 10:41 PM
