I have been reading about the nickel composite coatings using sila carbide. It looks like they are mixing
3 micron sila carbide into the plating solution, to create a composite plating Has this ever been tried with one of your kits? |
Not that we know of?
I have been reading about various nickel composite processes and I see that some use the electoless nickel plating process.
Is one process better than the other for producing a durable mechanical coating. Which adheres to the aluminum better? |
This is a description of the process, as you can see it refers to both processes.
This method is comprised of: adding an appropriate amount of ceramic fine powder such as silicon carbide or boron nitride to an electroless nickel bath or electric nickel bath; plating under agitation; depositing and compounding these fine powder into a plating film simultaneously with the plating; and baking the plating film as required to form a hard layer on the surface . |
We'll be bringing out a Boron Nitride Composite/Electroless Nickel System
which suit your purposes. Watch the web page for details.
| Something for you die hard polishers out there to chew on | thesound | Metal Polishing Questions | 15 | 12-03-2007 12:16 PM |
| Aluminum Engine parts - I'm ok, but I want perfection! | mansonozz | Metal Polishing Questions | 18 | 02-16-2004 06:09 PM |
| Polishing Aluminum (Engine intake) | RyanT | Metal Polishing Questions | 3 | 02-25-2003 07:53 PM |
| Repairing a Nickel-silicone plated engine cylinder | Abarber | Electroplating Questions | 1 | 12-12-2002 08:33 PM |
| Polishing aluminum chevy 350 cylinder heads | radioactive | Metal Polishing Questions | 2 | 12-04-2002 06:51 PM |
