Some large commercial plating barrels use this method. They call it a "dangler". Some danglers are large balls which simply ride on top of the parts pile. Others are thin rods which get surrounded by the parts. Of course, they are complicated devices using slip rings for electrical contact, while I'm trying to keep it simple. The tradeoffs aren't as easy to overcome as I figured. Quote:
Don't know how well this would work for nickle or copper. The current in zinc is fairly low, so it passes through the parts easily. Sean
Seans Zinc Plating page |
You might try the motors they use for making fishing rods. I built a rod making set up and the little motor seems as though it would have enough torque and turns pretty slow. I think it would turn your plastic basket.
Greg |
Greg:
However, I have the ideal motor now: barbeque rotisserie motor. They turn at just the right speed, 4 RPM, have gobs of torque, and are designed for continuous use. I have it set up for motorized use now, but still haven't quite got a fool-proof electrical connection to the parts, so haven't posted an update. When I figure that out, I'll be posting a full update. Thanks for the tip though! Sean
It's been a long road, but I finally have a functional motorized barrel plating setup:
Plating BarrelIt's not perfect, and I continue to investigate improvements, but if you can adapt the design to your own needs, go for it & post the results! Sean
Seans Zinc Plating page Last edited by seanc; 01-26-2009 at 09:21 AM. |
| Plating thread tolerances on nuts and bolts | dagobert | Electroplating Questions | 2 | 01-31-2009 03:27 PM |
| Another tumbler question for nuts and bolts | chefboiali | Metal Polishing Questions | 5 | 01-31-2009 02:53 PM |
| Plating nuts and bolts for car restoration | dinobelf | Electroplating Questions | 2 | 04-14-2005 09:47 AM |
| Aluminum prep for chrome plate | jm | Metal Polishing Questions | 1 | 02-02-2004 01:24 AM |
| Plating Nuts and bolts | markksheets | Electroplating Questions | 2 | 11-22-2003 10:58 PM |
