Old 01-08-2003, 08:12 PM
guschennells
Default removing chrome from brass?
What is the best/safest way so I can silver plate some Harmonica covers? Thanks
I'm into modifying and inventing
Old 01-08-2003, 10:14 PM
mcaswell's Avatar
Caswell Inc Founder
By using a weak solution of muriatic acid and a stainless steel or lead sheet, you can reverse plate the chrome off. Because chrome plate is a very thin layer, the chrome is stripped very quickly. You can also buff the chrome off with an abrasive compound, such as emery.
Have A Web Site?
Old 01-09-2003, 11:26 AM
48Buick
Hi:
I like to heat my muratic/hydrocloric (same thing)acid and water up to about 170 deg F. I use about 25% muratic to 75% water. ADD THE ACID TO THE WATER>>>>DONT ADD THE WATER TO THE ACID!!!Once I have degreased the part, I immerse it in the acid and it almost instantly fizzes, turns black and then the chrome is gone!
48Buick
Old 01-09-2003, 02:22 PM
guschennells
Default Removing Chrome from brass
Thanks for the additional details 48 Buick! So you don't use reverse current dechroming? Gus
Old 01-09-2003, 02:30 PM
48Buick
Hi Gus:
No, I dont reverse plate. It seems to attack the base metal and then I have to finish the part even more to remove the etching.
Usually you only have to remove chrome, activate the nickel, then either copper plate or nickel plate, then chrome.
Hope this helps.
48Buick
Old 01-09-2003, 05:52 PM
guschennells
Thanks again Buick, But what about if I'm wanting to silver plate. Does the Nickel have to be removed too? or activated? Gus
Old 01-09-2003, 06:09 PM
mcaswell's Avatar
Caswell Inc Founder
No - you can silver plate directly over nickel without activating.
Have A Web Site?
Removing small scratches from Chrome mlust Metal Polishing Questions 5 07-30-2008 02:39 PM
Removing blistered chrome from aluminum wheels? ozziepartsguy2003 Electroplating Questions 0 12-14-2003 06:26 PM
Removing the chrome surface from aluminum based auto trim jbashaw Metal Polishing Questions 6 10-01-2003 10:20 PM
Removing chrome from brass or base metal watch cases prsager Other Metal Finishing Questions 1 03-20-2003 06:06 PM
Plating Chrome over Brass mojobari Electroplating Questions 3 10-29-2002 03:28 PM
