Old 01-12-2003, 09:36 PM
chromo
Default Why don't parts stick together?
I was wondering, when tank plating, if the part has moveable pieces (like a watch band or necklace) why don't the pieces weld together into one solid object?
If the lead is attached to the end, then there must be a connection between the links in order to carry the currant through the whole piece. It seams if the parts are attatched to carry curant the gold or what ever would plate it all as one piece filling in any links where they touch each other. Is there something we need to do to prevent this, or does it just not happen?
thanks
Old 01-13-2003, 12:35 AM
mcaswell's Avatar
Caswell Inc Founder
The parts will fuse if plated very heavily, but otherwise won't fuse together.
Have A Web Site?
Old 01-13-2003, 10:09 AM
chromo
OH.
You mean if I had a necklace I wanted to plate I have to break all the links apart before tank plating??
I shall forgo some jewerely platting I was planing on doing then I am sure.
Actually I thought from what I read I could replate jewlery for customers in just a few minutes with a tank plating setup, obviousily if I had to take apart all the links and put it back together I couldn't do that then.
So the expandable metal watch bands would be impossable to do?
Also if plating items with a pen that run on batteries like watches, is it harmful to the watch? Magnetize it or damage the circiut? Don't want to ruin a good working watch makng it pretty. Would I need to disasemble it before platting the case?
thanks again
Old 01-13-2003, 12:59 PM
mcaswell's Avatar
Caswell Inc Founder
You should be brush plating all these parts. Brush plating will work very well.
You can buy a tank plating set-up, make or buy a brush plating wand, and use the solution from your tank to brush plate.
Have A Web Site?
Old 01-16-2003, 10:15 AM
chromo
Ok.
I could do that
thanks
Copy Chrome on engine parts and plastic, alot of can I's cgworth Copy Chrome Kit Customers Only 3 08-29-2005 12:38 PM
Having a really hard time getting CLEAR to stick. Heavykote Powder Coating Questions 5 05-18-2005 05:47 PM
Help cleaning just polished parts bonesaz Metal Polishing Questions 3 10-12-2004 06:58 PM
Machine to polish aluminum parts Zouky Metal Polishing Questions 0 09-05-2004 01:40 AM
Curing multiple parts of varying size in oven at same time?? Fireblade Powder Coating Questions 3 09-28-2003 08:10 AM
