I have the 4 1/2 gall. kit got the flash and acid copper to look good (pink) when i take it out of the tank but it doesn't fill the pits after five times at 45 mins. I still can't tell any different,the part is steel, 27sq.in. at 2.7 amps, 45mins at a time, and softy sand with 400 wet/dry paper. Thanks for any help.
Filling pits will take alot longer than that if they are very deep, I would sand the pits before plating if possible.
www.chrome-plater.blogspot.com |
What else is recommended for deep pits? I have also built up the copper, have used plum-loy to moderate success, but the deep ones are still an eyesore. They're just little pin holes, but are not filling in well. Any thing else to use? I do not want to grind the part down any more than i have... Has anyone had luck with the pitstop, and will it fill pin holes?...I mean these things are tiny, but deep. Thanks.
| Pits in Stainless trim-Help! | japr | Metal Polishing Questions | 8 | 05-07-2005 06:30 PM |
| HELP WITH GETTING OUT PITS IN ALUMINIUM WHEELS!!!! | johnnyb | Metal Polishing Questions | 10 | 04-27-2005 11:34 PM |
| filling small pits with acid copper | danderson | Electroplating Questions | 2 | 08-25-2004 07:55 AM |
| dull finish on old bolts with rust pits | fordmerc | Electroplating Questions | 1 | 02-15-2004 04:22 AM |
| New to Chrome - Repairing Pits | edseldude | Metal Polishing Questions | 1 | 05-14-2003 10:02 AM |
