Connect with Facebook
Closed Thread
Old 07-03-2006, 08:28 PM
shawnkloker's Avatar
shawnkloker is on a distinguished road
Default power supply
What would you recomend for a power supply?Amps and volts.I am an industrial electrician and can make what ever is needed.I intend for bike wheels to be the largest parts to be copy chromed. thanks, Shawn
Old 07-04-2006, 10:33 PM
nil8u
Default Re: power supply
Caswell has an idea using 34 & 1/2" lengths of #18ga nichrome wire attatched to bus bars from a residential power supply box. Each strand will give a resistance of 1.2 ohms. Using a 12v battery one lenght of wire will limit current to 10A, 2 - 20A, 3 - 30A and so on.
Old 07-06-2006, 06:17 PM
This isn't telling me what I want to know.
Old 07-06-2006, 07:38 PM
fly fly is offline
YOu want amps, 300 or more would be best for rims, but I don't know anything about copy chrome. Most of your smaller stuff will get by with 100 amps.
Old 07-07-2006, 08:57 AM
jimcarry's Avatar
jimcarry is on a distinguished road
Send a message via Yahoo to jimcarry
When you are plating with copy chrome you will need one amp per 32sq inches copper need one amp per 15 to 16 sq inches chemical stripping need one amp per sq inch i have a few power supplies the small one puts out 1.5amp max large one puts out 35amp max
Jim Eaton
Old 07-07-2006, 10:21 AM
Thanks Jim,35 amps seems alot easier to get than 300.
Closed Thread
Building power supply from manual dfarning Other Metal Finishing Questions 0 02-19-2006 12:56 PM
power supply Techno Electroplating Questions 0 09-20-2005 09:58 PM
anno power supply jasonboulanger Anodizing Questions 2 01-07-2005 06:48 PM
Power supply aalamo Electroplating Questions 5 11-24-2004 10:21 AM
Anodizing Power Supply Q's jnbsystems Anodizing Questions 7 10-02-2003 11:33 PM
