I know this question has probably been asked a million times but can anyone tell me how to properly prep a part for flash copper plating. The part I am plating is about 30 sq" and is steel. It was painted but I stripped the paint and have sanded the part down to 400 grit and polished with black compound and a twine sisal wheel. It looked great and passed the water break test but the flash copper is not uniform. I plated the part at 1.4A for about 15 mins. Is this long enough? When I pulled it out there were some areas that were dark and some areas that were really light. I forgot to mention that when I pickled the part in #4 pickle the dark blackish spots became appearant. I dont think it is because of the copper. What would cause a dark discoloration in certain areas after it was pulled from the pickle?
I have tried a couple of times on this part and every time I think I have it down the bright acid copper that is plated after the flash copper doesnt stick. What am I doing wrong? Also when the manual says to rinse does it mean with distilled water or tap water. I am thinking distilled but on the website it shows the water break test done in a sink. Also it says to rinse the SP degreaser off in hot water and the pickle should be rinsed off with cold water. Is that distilled cold water? Any help would be appreciated. Thanks, Lance |
This is what I do for steel. After you have sanded and buffed, clean all the buffing compound off with castrol super clean, then use dish soap and hot water to clean it some more. After you pass water break, I only use distilled water from that point on and never touch the part unless I have on nitril gloves. A quick dip in pickle #2 (not 4), then rinse with a spray bottle, then go into the flash copper live. Rinse and go directly into acid copper live, if you let it sit for a little while, then use the pickle #4 before acid copper. Read the manual more, it's all in there except that the SP degreaser doesn't do **** to buffing compound.
You mentioned black spots. I'd suggest this may be because the part had been zinc plated at some point. Just to make sure, prior to sanding, dip in any acid for a few minutes, (weak sulfuric/muriatic etc) if the zinc is present, it will turn black and you can then sand it off.
| PLATING POT METAL............... | 48Buick | Plating Pot Metal | 31 | 08-29-2007 11:40 AM |
| Chemical cleaning | jacob2025 | Powder Coating Questions | 1 | 03-13-2006 08:47 AM |
| self cleaning ovens | Blademan | Powder Coating Questions | 3 | 08-06-2004 10:16 AM |
| Part is 1/2 blue 4A, 1/2 Deep red. red fades when boiled | frubino | Anodizing Questions | 1 | 07-27-2004 01:56 PM |
| A few question to help a beginner | Cyberave68 | Anodizing Questions | 6 | 06-08-2004 08:53 PM |
