Old 01-26-2003, 12:25 AM
cshu
Default Removing old plating
Must I remove old nickel plating before tank plating. Can I plate then polish nickel and plate the same piece again for higher luster? Also, for small parts (three inch by 1/4 inch strips of .040" steel) is brush plating better than tank plating? Thanks in advance.
Old 01-26-2003, 01:30 AM
mcaswell's Avatar
Caswell Inc Founder
You can nickel plate over existing nickel plate. You have to use an acid pickle called Nickle Activator. It's in the manual.
Brush plating is good when you can't get an item in a tank for whatever reason, like plating a car emblem while still on the car. Tank plating generally gives a more uniform plate.
Have A Web Site?
Removing Tin Plating gsw3 Electroplating Questions 2 05-06-2005 09:16 PM
Removing copper plating.......Help! Coltsaa Electroplating Questions 8 11-03-2004 11:34 PM
Removing copper plating? Help...... Coltsaa Other Metal Finishing Questions 0 10-11-2004 08:58 PM
Removing old plating model_t Electroplating Questions 1 12-16-2002 10:02 PM
Removing Nickel Plating drdarvocet Electroplating Questions 5 10-25-2002 07:55 PM
