Old 01-28-2003, 07:46 AM
chromo
Default Plating and high heat
How does high temps will most plating with stand?
I read something abut the blueing on cycle exhaust being from a low quality chrome job, mostly jap bikes which I ride alot of. Actually I thought all chromed exhaust did the blueing at the engine if used?
I want to plate alittle on a woodburner, it gets pretty hot. Sometimes don't want to stand too close, and of course no touchy.
Will plating hold up on something like that? I'll be using a plug n plate if I do those areas. Not sure off hand which solution I'll use, gold or chrome.
The material is steel.
I could live with a blueish tint from the heat with chrome as long as it doesn't burn off, if need be.
Also if plating gold, chrome has to be removed first? So if I want to do chrome plateing and gold lettering, I would use nail polish or laquer to mask/paint on the lettering before chrome plating, that area won't chrome right.
Then I remove the mask before gold plating. So, would I need to mask the chrome before doing the gold? Or will the gold just have no effect over the chrome and I don't have to worry about over lapping?
chromo
Old 01-29-2003, 01:15 AM
mcaswell's Avatar
Caswell Inc Founder
Most plates, if done properly, will hold up fine to high temperatures.
Yes, you need to remove the real chrome first. Yes, use lacquer to mask off certain areas and they won't plate.
You're plating using Copy Chome™ not real chrome, so you'll need to mask that off too, otherwise the gold will plate over the Copy Chrome™
The included pens allow you to be very precise with the plating solution, so if you have a steady hand, you might be able to get away without lacquering.
Have A Web Site?
hard chrome plating dcarter Electroplating Questions 4 04-27-2008 10:21 PM
PLATING POT METAL............... 48Buick Plating Pot Metal 31 08-29-2007 11:40 AM
George W. aka GSW3 aalamo Electroplating Questions 21 12-17-2004 07:51 PM
Need Nickel Plating (small job) in NYC (could use mail) higginsjr Services Offered/Wanted 0 03-10-2004 10:14 AM
High quality silver plating needed. clovenguth Services Offered/Wanted 0 04-02-2003 01:58 PM
