Old 08-21-2006, 11:34 AM
carltyson is on a distinguished road
Smile Need to plate a 55 gal Steel Drum - Suggestions Needed!!!
I need to gold plate a 55 gallon steel drum for a friend. How do you suggest that I do it to make it great. Thanks.
Old 08-21-2006, 12:35 PM
Rasper will become famous soon enough
Default Re: Need to plate a 55 gal Steel Drum - Suggestions Needed!!!
I don't know, but I'd love to have one. What a hoot. A gold plated 55 gallon drum. Right now I'm making a four foot long pair of high heel shoes out of stainless steel.
Please post photographs when it's done.
Richard
Old 08-22-2006, 12:16 PM
mcaswell's Avatar
Caswell Inc Founder
You'll need to nickel plate it, then gold plate it. I'd suggest this will be expensive.
Set the drum so it rotates in a shallow tank of nickel and with plenty of anodes. Plate each submerged section of the drum for 30 mins, then rotate it to the next uplated section etc etc.
Finally, buff the drum until the nickel is shiny, then brush gold plate it.
Quite the task!
Have A Web Site?
Old 08-23-2006, 11:03 AM
carltyson,
As Mike says mucho expensive! In addition to what Mike suggested, you may want to looking in to applying gold leaf or spray painting it gold.
John
Old 09-11-2006, 11:32 AM
Moderator
bhhodges is on a distinguished road
im thinking it wont be possible to acomplish this in a regular plating bath if one end is open maybe but then you lose volume when the drum is placed inside the bath and if the bottom is still in place without holes then it seems to me like it will be pretty hard to force the drum into the bath closed end first....... wouldnt the steel need to have a flash copper plating applied first,then nickel with gold last?? maybe im missing something??
Old 09-19-2006, 08:13 PM
BPP BPP is offline
BPP is on a distinguished road
A good plating shop can nickel plate it for you and have it ready to brush gold.
Seems like a major task, but I have seen much bigger tasks done. The hardest part is getting started.
I work mostly with classic lowriders, and have seen gold plated frames (full chevy frames front to back 18ft long) , gold plated transmissions, gold plated engine blocks, gold plated gas tanks, you name it.
Old 09-30-2006, 05:49 PM
mcaswell's Avatar
Caswell Inc Founder
Another way to get a gold finish would be to invert he drum over a propane burner, like you cook a turkey broiler with.
Powder coat the drum outside with Mayan Gold powder, then light the burner to heat the drum's inside. Crazy? More than likely, but it MIGHT work. The finish would be quite reasonable, I think.
Do it out of doors.
Have A Web Site?
steel canteen plating suggestions ownthenight Services Offered/Wanted 3 12-12-2006 04:58 PM
Stainless Steel Polishing Needed mross Metal Polishing Questions 3 09-15-2005 08:39 AM
Stainless Steel Polishing Needed mross Services Offered/Wanted 0 09-14-2005 12:17 PM
Copper plate over soder and steel keala Electroplating Questions 3 06-28-2005 07:56 PM
How to plate Nickel over old Nickel when steel shows through ASHENASH Electroplating Questions 3 04-22-2005 03:03 AM
