I was considering purchasing a Plug n Plate kit to try to build up a leaky rotary valve for a trombone (solid brass valve body). I think the usual way to do this would be to build it up with copper plating, lap it in, and nickel-plate over the copper (to reduce corrosion, I assume). Would the combo nickel/copper Plug n Plate kit work for this purpose? The reason I'm thinking of the Plug n Plate kit rather than a larger setup is that it seems more economical and would take up less space in my tiny work area.
Is copper the best way to build up thickness, or could I plate either nickel or silver directly onto the brass? Thanks. |
| Improving Plating Performance | jimcarry | Electroplating Questions | 0 | 09-28-2005 08:50 AM |
| Gold Plating Musical Instrument Parts | jedgrhoovr | Electroplating Questions | 0 | 04-03-2005 11:48 PM |
| Gold plating instrument mouthpieces | etgreece | Electroplating Questions | 3 | 01-28-2005 11:37 PM |
| Plating Hyd. Valve Spools w/ Hard Chrome | Daveleeander | Electroplating Questions | 0 | 04-27-2004 02:55 PM |
| musical instrument valves | Russ Kaiser | Electroplating Questions | 1 | 03-22-2002 12:06 PM |
