+ Reply to Thread
Results 1 to 2 of 2
Thread: copper peeling from plastic
  1. #1
    Default copper peeling from plastic
    Hello ,
    Seems that the conductive paint goes on the plastic smooth and the copper plates great to it but the problem comes when the part is buffed before nickle . While buffing the copper raises up from the plastic , this is not a heat issue as I buff it slowly and feel it very often to make sure they is no heat ( its has even done it from hand sanding ) once that the copper has raised up you can peel it off from the plastic and some parts under the plating is still the color of the plastic ( like im peeling the paint off with the copper ) The plastic is roughed up before painting and all goes well until buffing . Sometimes it sticks well but raises while in the chrome tank and then same story ,peel it off and you looking at the plastic hardley no paint ...... thanks in advance
    Share with Facebook
  2. #2
    Join Date
    Nov 2001
    Location
    Lyons, NY USA
    Posts
    1,793
    This is a surface prep problem.
    Please post a problem report in our PRS system.
    Have A Web Site?
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Flash Copper Problem
    By gwjohnso in forum Plating Pot Metal
    Last Post: 02-27-2007, 11:41 PM
  2. "Sandwiching" Acid Copper
    By AresP in forum Electroplating Questions
    Last Post: 08-27-2004, 08:19 PM
  3. Strike Copper or Acid Copper over Nickel?
    By mdarr in forum Electroplating Questions
    Last Post: 07-13-2003, 01:53 AM
  4. Strike copper or bright copper after zincate?
    Last Post: 06-29-2003, 02:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
