Antique Britannia Metal Plating?
Hello fellow Platers, Polishers and Powder Coaters! I have just been tasked to perform restoration on several antique (1870's) silver plated items from a local Antique Dealer. I have determined that the base metal to be an alloy called Britannia Metal, similar to Pewter, and comprised of mostly Tin with trace amounts of Copper and Antimony.
The question that I have is what would be the best way to start the surface preparation for the plating procedure? Each piece will require a thorough cleaning to remove tarnish and oxidation before making a final evaluation of the work to be accomplished.
Will SP Degreaser or an Acid Pickle harm the base metal in any way? Most of the original silver has been polished away due to the age. (There are no signs of an original strike coat of anything at this point) What do you recommend as a suitable way to remove the remaining silver plate without disturbing the underlying base metal? (It is all very intricately carved, engraved and embossed.)
To treat it like Pewter, a strike coat of Flash Copper would be needed first. Would you recommend Nickel over the Flash Copper first or go straight to Silver after the Copper Strike?
Thanks!
