Old 11-03-2006, 05:39 PM
MrPontiac is on a distinguished road
Default Im new 3 amp or 5 amp for the $$$$
Just got my kit and it looks awesome, can,t wait to get started, all i want to do is yellow zinc plate some carb. lingage, should i get the 3 amp or 5 amp, ill spend the extra 20.00$ or so if the 5 amp gets the job done faster?? All my parts have been glassbeaded washed down with prep clean, any input
Old 11-03-2006, 07:57 PM
lcaswell's Avatar
Caswell Inc President
Default Re: Im new 3 amp or 5 amp for the $$$$
The 5 amp won't get the job done faster, it will just do bigger parts. You need 140ma/sq in to zinc plate.
Lance Caswell
Have A Web Site?
Old 11-03-2006, 10:09 PM
Lance, could you explain your answer so as i know what to buy in a power source 140ma/ means nothing until i learn more, so the 3 amp will be sufficient??
Old 11-03-2006, 10:24 PM
Inferno is on a distinguished road
You need 140 ma per square inch. You need to first calculate the surface area of the part you are plating and multiply that by 140 ma/sqin to give the total amperage to supply the part.
I would get the 5 amp, I bought a 3 amp but with the new zinc formula it takes more current, and am finding myself wishing I had a larger supply.
Old 11-04-2006, 01:25 AM
sswee's Avatar
Moderator
MrPontiac,
140ma/sq in to zinc plate written out is 140 milliamp (.14 amps) per square inch of surface area. In plating, the current does the work. I'm with Inferno, you'll be happier with the 5 amp supply in the long run.
SS
