+ Reply to Thread
Results 1 to 7 of 7
Thread: gold plating on brass
  1. #1
    Default gold plating on brass
    I'm new to this stuff, and I have a bit of a dilema. I am working on a piece that was originally gold plated. When I started, it was heavily tarnished. Starting with black, I used various compounds and wheels to clean it up. At this point, I had a pretty nice looking piece of brass. To restore the original finish, it must now be gold plated. I am using Fastgold.
    I plated the piece with the Fastgold. This was surprisingly simple. I then polished with blue compound on cotton flannel wheel. Excellent finish. However, my untrained eye cannot distinguish whether I am looking at a gold plate finish, or the same nice brass finish I had before I started plating. It is possible that my plating process was flawed, or that I took the new gold off when polishing. How would I know?
    For this piece to be 'as original', it must be gold plated, even though the brass finish is rather nice. Is there some kind of simple test I can do to determine the finish is in fact gold?
    Share with Facebook
  2. #2
    Join Date
    Nov 2001
    Location
    Lyons, NY USA
    Posts
    1,794
    Gold plating should really be done over a nickel plate on brass. Otherwise the brass will tarnish and turn green through the gold.
    So you'll easily be able to see where you put the gold when going over nickel. A fairly thin layer of nickel is sufficient.
    Have A Web Site?
    Share with Facebook
  3. #3
    The plating manual states that Fastgold "will plate over nickel, sterling gold, gold, rhodium, copper, brass, and bronze". Is this not correct? I understand distinguishing the color is a bit of an issue, but tarnishing and turning green was not part of the deal.
    Share with Facebook
  4. #4
    Join Date
    Nov 2001
    Location
    Lyons, NY USA
    Posts
    1,794
    It depends on the application. Fastgold will plate onto brass, and in many situations it will be fine. In more aggresive environments, it may tarnish. Remember gold goes on at 1-2 millionths of an inch thick. Thats fairly easy to rub off, especially on jewelry which is continually being rubbed.
    Have A Web Site?
    Share with Facebook
  5. #5
    Got it, thanks.
    OK. If I start with good brass, I would want to brush plate with nickel (nickel wand), then brush with Fastgold (SS wand).
    I know that the key to a good finish with gold plate is good surface preparation (polishing, mostly). If I am going to plate the brass with nickel before I plate with gold, is the surface preparation equally important with both layers?
    Assuming the brass is good to begin (no pitting, etc), I would finish up the brass with white compound on a loose wheel, finish up the nickel with red on cotton, and finish up the gold with red on cotton. Is that right?
    Share with Facebook
  6. #6
    Join Date
    Nov 2001
    Location
    Lyons, NY USA
    Posts
    1,794
    Sounds like you're on the right track.
    Have A Web Site?
    Share with Facebook
  7. #7
    Join Date
    Nov 2008
    Location
    Tucson,Az
    Posts
    114
    Thumbs up Re: gold plating on brass
    Hello,
    I have plated on brass for over 25 years. The nickel is your barrier!
    Remember the gold thickness can vary depending on the gold type selected.
    Also, if you polish gold you may be removing gold.
    Review the following procedure:
    If you want to plate on brass:
    1. Buff and polish brass.
    2. Copper strike- Copper under plate is your barrier to brass. optional
    3. Copper plate (100 microinches).optional
    4. Buff/polish if you wish.
    5. Clean/acid activate.
    5. Plate nickel (100 microinches).
    6. Activate acid dip.
    7. Plate gold (50 to100 microinches).
    Good Luck,
    NOL4154
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Question on gold plating
    By oldtoys1961 in forum Electroplating Questions
    Last Post: 05-07-2008, 10:41 PM
  2. Gold Plating and Nickel plating
    By tzmandevil in forum Electroplating Questions
    Last Post: 09-16-2005, 09:11 AM
  3. Brass Plating Tank
    By agugliel75 in forum Electroplating Questions
    Last Post: 02-06-2004, 08:50 AM
  4. Question on gold plating brass.
    Last Post: 12-29-2003, 04:45 PM
  5. Plating Gold over Brass
    By mojobari in forum Electroplating Questions
    Last Post: 10-08-2002, 09:28 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
