First off, super, i used the heaters up to 140 degrees and soaked my parts for 30 min. In my other tank i have both plates in with a jumper in between to get positive to both plates, got the heater in distilled water, added chromate crystals then about 1 1/2 teaspoons of yellow brightener, for 30 min. my part is suspened off a 1/2 copper pipe with copper wire, for 30 min. so nothing i see nothing happeneing?? My question maybe i should use just yellow brightener and no crystals, directions are not helpfull
Can you please elaborate on your procedure? I assume you're trying to zinc plate, then yellow chromate something??
What's the part surface area? What metal is it? What are you heating to 140F? You added chromate, then yellow brightener I'm not sure what you're referring to here?It kinda sounds like you've added the chromate to your zinc plating tank...which would be disastrous.
-- Lance Caswell Caswell Inc http://www.caswellplating.com Need Support? Visit our online support section at http://support.caswellplating.com Have A Web Site? Why not join our affiliate program and earn 15% of all sales. Join at http://www.caswellplating.com/affiliate.htm Please support the moderators on our site by leaving reputation for their helpful posts. Read more here. |
No zinc plating at all, i have small lingage off carburators steel, yes i used the zinc chromate crystals on page 96 referring me to do and then i did ad the yellow chromate consentrate to that?? Is this where i went wrong?? Directions i fill are poor for this procedure. yes i had temp up to about 120 then put part into solution for 30 min. part came out gray but the solution in the tub is yellow.
Zinc chromate crystals? (No such product)
Yellow chromate concentrate? Do you mean 'yellow chromate crystals'? I'm not sure what you are refering to here. Are you saying you added the yellow chromate to something else? Look at your invoice and check you have the terminology correct, please. Then explain exactly what you added to what.
I spoke to you on the phone today and you had mixed the Zinc Plating Concentrate Part B with the Yellow Chromate.
When you get the new Part B we're sending, please feel free to contact us if you have any questions before mixing again.
Mr. Caswell, just wanted to inform you it worked like a dream, mixed parts together and got super results, Is it really important to soak the parts for 20 min. to half a hr.?? though?? Rectifier set a 5 amps with 12 volts, rinsed in warm water when dryed they look great, many thanks for your help!
I really have only one last question i believe it is as follows, I only want to yellow chromate my parts that have been blasted and cleaned, do i have to zinc plate em in a bath to achieve this goal
Im still learning the basics, alot of fun!!
Yes you would have to zinc plate them before you yellow chromate them. The yellow chromate is a conversion coating that converts the outer layer of zinc into a more corrosion resistant finish, so you need a layer of zinc for the chromate to work.
| PLATING POT METAL............... | 48Buick | Plating Pot Metal | 31 | 08-29-2007 12:40 PM |
| Part cleaning. | nil8u | Electroplating Questions | 9 | 08-22-2006 01:23 PM |
| removing zinc | modadds | Electroplating Questions | 4 | 04-11-2005 02:13 AM |
| Part is 1/2 blue 4A, 1/2 Deep red. red fades when boiled | frubino | Anodizing Questions | 1 | 07-27-2004 02:56 PM |
| A few question to help a beginner | Cyberave68 | Anodizing Questions | 6 | 06-08-2004 09:53 PM |
