Old 11-12-2006, 12:10 AM
MrPontiac is on a distinguished road
Default Sould i ad zinc brightener??
I successfully yellow zinc plated some parts recantly, for the first time, im pleased but there is no shine to the parts, they are yellow in color but they are of a dull yellow, really would would like to see a shine to them, question is should i ad some brightener to the solution while im zinc plating?? How much??
Old 11-12-2006, 12:17 AM
lcaswell's Avatar
Caswell Inc President
Default Re: Sould i ad zinc brightener??
Based on your previous posts, I'm assuming that the reason your parts are coming out dull is too much current.
Mr. Caswell, just wanted to inform you it worked like a dream, mixed parts together and got super results, Is it really important to soak the parts for 20 min. to half a hr.?? though?? Rectifier set a 5 amps with 12 volts, rinsed in warm water when dryed they look great, many thanks for your help!
If you're using 5 amps, you part should be 35 sq in. Is that correct?? You haven't said what the surface area of this part is, so I can't say for sure.
It's important to post as much information in these posts as possible, otherwise people are just guessing. Read the sticky at the top for the info that's important.
Lance Caswell
Have A Web Site?
Making my own Zinc Anodes? cdnpont Electroplating Questions 2 02-18-2006 08:25 AM
Zinc Plating an old auto radio case engineerscott Electroplating Questions 1 02-18-2006 02:08 AM
CopyCad & Zinc failure - electrolyte problems? seanc Electroplating Questions 4 11-08-2004 10:16 AM
How dark is the olive drab? + zinc question. jbvan Electroplating Questions 4 02-01-2003 02:12 AM
Zinc Brightener 68goat Electroplating Questions 1 01-09-2002 04:05 PM
