Hi, I am brand new to this whole thing so I have a few questions to ask about plating a Colt .45 1911 handgun.
First off, an opinion question, What would you plate a colt .45 if you could? I was thinking that the Black Krome would look especially sweet. I've also looked at Nickel plating it as well. Any other suggestions? Am I supposed to plate the barrel and if so, do I plate the inside? What kind of prep work must be done to the piece. Just basic buffing and polishing? The gun is already in very good condition and is blued but the bluing is wearing off so I would like to have it plated. It says on the Caswell website that the Black Krome kit can be applied on steel. Does this mean that I do not have to plate it copper, then nickel, then chrome? Would the electroless Nickel plating kit give me good results as well? Is there anything else in particular that I should buy from Caswell to do all of this? When you buy the kit do all instructions come with it? Thanks a lot everybody. Grambo |
I can let you know what I started with
1 a polishing motor preferably a 3/4 hp 3450 rpm a sisal wheel spiral sewn wheels at least two One canton wheel. ( This wheel works great for final polishing with blue compound) Black compound. Brown compound. White compound. Blue Compound. These compounds are used in steps and you can read more about this here. http://www.caswellplating.com/buffs/buffman.htm Then your plating kit with a rectifier. On the above site you can also look at the pick a kit helper. Also the Caswells sales team can help you to determine what other products you might need. Good Luck
Jim Eaton |
| Looking to purchase pro type gun from caswell have questions | chicagorich | Powder Coating Questions | 10 | 03-23-2006 02:05 AM |
| Improving Plating Performance | jimcarry | Electroplating Questions | 0 | 09-28-2005 09:50 AM |
| A couple carb plating questions | KenL | Plating Pot Metal | 0 | 01-23-2004 09:34 PM |
| First time plating, some questions.... | vic valis | Electroplating Questions | 1 | 09-29-2003 06:39 PM |
| Questions on plating a flute | Hoomi | Electroplating Questions | 1 | 03-08-2003 11:16 AM |
