Obviously, the "trimming" process will break the chrome "seal" on this part. My question is, must I rechrome the entire shroud/bracket assy or can I rechrome just the exposed area where the "seal" is broken. I'm not concerned that a small part of the bracket might be a different color--can I simply "seal" that portion where I've broken the "seal" with another of your products. I'm new to this whole business of plating, kindly forgive my ignorance. Greg Schwob gschwob@erols.com |
I'm not really sure what you're trying to do here.
I am pretty positive that I know what you are trying to accomplish. I had a similar problem with a friend of mine that needed to trim a swingarm axle cover in order to install a side mount license plate bracket. Here's how I did it.
Bought a 6 dollar pack of cut off discs for my dremel. Trimmed the part close to the desired shape, and then used an EXPAND A WHEEL that I bought from CASWELL to shape and smooth the roughness of the cut. The cut off discs worked really well and did not damage any of the plating on the surface. I then brush plated the edge that was cut with nickel just to seal the metal at the cut and prohibit corrosion. It was very simple and turned out really well. Shevalik |
| copy chrome vs triple chrome plating | splbnd27 | Electroplating Questions | 18 | 06-21-2006 08:35 AM |
| Copy chrome and resistance to rust, tarnish, dulling? | phunkmastakrez | Copy Chrome Kit Customers Only | 6 | 08-25-2005 10:13 AM |
| Copy Chrome Start-up | Elitefisherman | Electroplating Questions | 10 | 04-18-2004 05:24 AM |
| Chrome (re)plating question - howto | olaf_sc | Electroplating Questions | 1 | 07-29-2003 03:00 PM |
| Hard chrome vs triple chrome | butters | Electroplating Questions | 1 | 02-20-2003 12:35 AM |
