With my plastic bucket insulated , even after 2 hrs, my cad. solution won,t go part 95 degree,s with a single heater, anybody else seeing this problem?? Im using a 1 gal. and 1/2 system. If i use both heaters im really limited on space to cad parts. Im being told a Porcelain pot is better to use?? true?? Also abody know the shelf life of the cad solution sitting
copy cad power problems I'm using a 200w aquarium heater in a 3 gallon NON-insulated tank and have no problems getting to 100º+. Your heater is either too small, or defective. Quote:
Sean
Seans Zinc Plating page |
My workbench is in an unheated basement. In the summer, when it's 90º outside, the basement is 70-75º. Takes about an hour to get it to 105º. In the winter, below freezing outside, the basement is about 45º. With the old formula, it took about an hour to get it to 70º. Haven't used the new formula in winter yet, but from the above, I'd say about 2 hours to go from 45º to 100º. Sean
I have the 1.5 gal buckets so it's not too bad to start with but I wanted to conserver power($$$) and get things up to working temp a but quicker. What I did was go to a local HW store, and purchase some of that insulating bubble wrap that's coated with aluminum foil. I then cut ot to fit and wrapped it with duct tape. I can now get things up to temp in a hour or less by covering the tank with aluminum foil, and it hold the heat much longer a well.
| Life Expectancy of Copy Cad | rockitdoc | Electroplating Questions | 1 | 12-18-2006 07:09 PM |
| copy cad power problems....I think?????? | lintmann | Electroplating Questions | 9 | 10-20-2006 11:39 AM |
| Copy Cad Stainless Steel? | rockitdoc | Electroplating Questions | 2 | 10-19-2006 03:48 PM |
| Copy Cad problems | only658 | Electroplating Questions | 2 | 02-18-2006 11:29 AM |
| Copy Chrome? / Temp? | hefrod | Electroplating Questions | 4 | 08-18-2005 02:47 PM |
