How do you guys handle rinsing? Do you use a single rinse tank for all chemicals/solution, or do you have a seperate one for each process?
If using a single one, should I be worried about cross contamination or adhesion problems during plating, and are there any exceptions to using a single rinse tank? I have read that the rinse water can be used as for top up but I'm not so sure this is a good idea with a single rinse tank. BTW, I am using the Copy Cad and Yellow Chromate solutions so my concerns are centered around these use of these in particular. Comments and sage advice welcome. |
You should have a seperate rinse tank for each solution - this way you can use your rinse water to top up your plating tanks to replenish evaporated water.
An added bonus is that you create a closed loop system - zero waste and no disposal issues.
-- Lance Caswell Caswell Inc http://www.caswellplating.com Need Support? Visit our online support section at http://support.caswellplating.com Have A Web Site? Why not join our affiliate program and earn 15% of all sales. Join at http://www.caswellplating.com/affiliate.htm Please support the moderators on our site by leaving reputation for their helpful posts. Read more here. |
| Rinsing and the Enviroment | need1moretool | Electroplating Questions | 13 | 02-06-2005 12:53 PM |
| Rinsing Process | BryanD | Electroplating Questions | 6 | 12-23-2003 12:13 AM |
| Rinsing Of Parts | rdanielewski | Electroplating Questions | 1 | 12-08-2002 11:17 PM |
