Old 12-20-2006, 05:19 PM
ms042180's Avatar
ms042180 is on a distinguished road
Talking Muriatic Acid/Water bath to clean Stainless Bad?
Hello, does dipping stainless steel parts in a 1:10 bath of Muriatic Acid and Tap Water (respectively) bad for the stainless steel's corrosion resistance? I did some test parts and rinsed them off in a bath of warm water and they look great after a couple hours, but will this cause the stainless to lose some of its corrosion resistance sooner than if I just leave it alone?
Thanks in advance! #=D
--Mike--
Old 12-23-2006, 10:41 AM
sswee's Avatar
Moderator
Default Re: Muriatic Acid/Water bath to clean Stainless Bad?
ms042180,
The corrosion resistance of stainless steel is in the material makeup. Unless the SS has an extra corrosion resistant coating applied to it, dipping the parts will not change it's corrosion resistant properties. The level of resistance to corrosion is due to the material grade.
SS
Old 12-23-2006, 12:08 PM
ms042180's Avatar
Talking Re: Muriatic Acid/Water bath to clean Stainless Bad?
Thanks! I guess that was more of a "DUH" question. After I thought about it, it made total sense.
--MIke--
Product to Keep Stainless Clean and Polished dschribs Metal Polishing Questions 7 07-16-2005 02:44 AM
