I am copper electroplating a plastic piece with your Acid copper plating kit. I am using the Silvaspray you recommended. I nicely prepared the plastic substrate (high surface finish) and then sprayed the silvaspray onto it..then allowed it to dry. After spraying the substrate surface becomes little rough...this results in similar copper plating results out of the acid copper plating bath...
What should be done to improve the surface finish after plating ?? ( sanding can be done after plating, but is'nt there any other method to improve surface finish?) Can the dried silvaspray sanded a bit? After plating surface finish problems only exist in plating plastics(silvasprayed) ..I get nice surface finish after plating when I try metals..! Please HELP !! Thx Neeraj |
You need to buff the copper. No way around it.
-- Lance Caswell Caswell Inc http://www.caswellplating.com Need Support? Visit our online support section at http://support.caswellplating.com Have A Web Site? Why not join our affiliate program and earn 15% of all sales. Join at http://www.caswellplating.com/affiliate.htm Please support the moderators on our site by leaving reputation for their helpful posts. Read more here. |
You could also alter your spray gun, and perhaps add a little more thinner to the Silvaspray.
I also read in your other post that you're using 2amps/sq in for your current density. This is VERY high and will result in a very grainy plating. Lower your CD to 70-100ma/sq in and you'll probably see better results.
I mistakenly typed 2 am/in2; I am using CD of 0.2 a/in2.
I want to use copper as a final layer of plating..What should be done to avoid discoloration of plated copper. it turns dark red in patches upon washing with distilled water. |
| Something for you die hard polishers out there to chew on | thesound | Metal Polishing Questions | 15 | 12-03-2007 01:16 PM |
| Improving Plating Performance | jimcarry | Electroplating Questions | 0 | 09-28-2005 09:50 AM |
| Zinc plating on running seal surface? | Broke | Electroplating Questions | 1 | 12-06-2004 02:52 PM |
| Show Quality Plater wanted at Baltimore plating shop | jkurland | Services Offered/Wanted | 0 | 03-23-2004 09:43 PM |
| surface area for electroless plating | tepece | Electroplating Questions | 1 | 02-09-2003 08:54 PM |
