I am plating small pieces of plastic with the help of acid copper plating kit....I am using a current density of 2A/in2...When I take my plated pieces out of the bath and wash them, they turn dark orange/discolored..why is this happening? is it oxidizing? is there any way to prevent it? what should be done after the part gets plated..should it be washed in cold water or hot water??
I by mistake typed 2 A/in2, I am using a current density of 0.1 to 0.2 A/in2.
Copper is my last layer of metal over plastic (Steriolithography plastic) I want to avoid oxidation, is buffing the only way out? |
neeraj_bapat,
Once you get your final coat of Copper on, the buff and polish it to the shine that you desire, (Be careful not to buff down into the underlying plastic) then you could apply some anti-tarnish compound such as FLITZ LIQUID METAL POLISH. You could also use the Cape Cod Polishing Cloths to clean and protect your final plate. This may be more suitable than buffing if your plating is thin. Another alternative and a more permanent solution would be to use some of the VHT Genuine Lacquer as a final clear coat, but the piece would still have to be lightly buffed first. All of these products are available through the Caswell website.
Curtis Ashcroft M and C's Plating & Powder Services |
| Blackening of copper and tin & methods for tin plating | Bulldozer | Other Metal Finishing Questions | 2 | 01-07-2007 04:15 PM |
| Copper Plating rates in acid | jlacy | Electroplating Questions | 5 | 11-08-2005 06:47 PM |
| I did a dumb thing - now how do I remove copper plating? | Mark3316 | Other Metal Finishing Questions | 0 | 05-19-2005 03:57 PM |
| "Sandwiching" Acid Copper | AresP | Electroplating Questions | 1 | 08-27-2004 09:19 PM |
| Acid copper plating problem! Attention Fibergeek | Gabourie | Electroplating Questions | 10 | 08-15-2004 12:24 AM |
