Hi forum.
I have the nickel cobalt.copy chrome setup, tanks, solution, current controlled power supply, heaters, agitator, etc. I want to do zinc plating, what do I need? A different solution and anode? I also have the Caswell Plating manual, although it is probably 3-4 years old. TIA JH |
You need a complete zinc kit. There's nothing in the kits that is interchangable (including the manual in your case because the zinc instructions are updated).
-- Lance Caswell Caswell Inc http://www.caswellplating.com Need Support? Visit our online support section at http://support.caswellplating.com Have A Web Site? Why not join our affiliate program and earn 15% of all sales. Join at http://www.caswellplating.com/affiliate.htm Please support the moderators on our site by leaving reputation for their helpful posts. Read more here. |
I'm confused. The zinc kit is:
# 2 x 2 Gal Plating Tanks & Lids # 2 x 4" x 8" Zinc Anodes # 1 Quart Copy CadŽ /Zinc Solution (Makes 1.5 Gals) # Zinc Brightener # 1 Pack Degreaser (Makes 4 Gals) # 2 x 300W Ceramic Heaters # 1 x Thermostat # 1 x Agitation Pump # Abrasive Nylon Wheel # The Caswell Plating Manual # Free Technical Support So I can't use the heaters, tanks agitation pumps that I already have (rinsed and cleaned)? Isn't the degreaser the same? Is an updated manual available for sale? I don't want to buy a bunch of stuff I already have.... JH |
You can use the same degreaser, but we strongly advise against reusing pumps/heaters etc from other kits, no matter how well you clean them. You'll contaminate your tank with the other chemical. Considering how cheap the heaters and pumps are, in relation to the plating chemicals, it's simply not worth it.
| triple chrome vs. nickel/chrome vs. copy chrome | spectraflamed | Electroplating Questions | 4 | 01-21-2007 10:07 AM |
| copy chrome vs triple chrome plating | splbnd27 | Electroplating Questions | 18 | 06-21-2006 07:35 AM |
| Anyone setup for production Copy Chrome | giles0 | Services Offered/Wanted | 2 | 08-19-2005 10:25 AM |
| Copy Chrome Start-up | Elitefisherman | Electroplating Questions | 10 | 04-18-2004 04:24 AM |
