I'm having all kinds of problems getting nickel to stick on brass.
I polished the brass with Caswell buffing compounds, cleaned them off real well with acetone. Plated with a rectifier set at 5V. Of the 3 parts I was working on, 1 seemed to take the plating fairly well in most spots. There was a couple areas that just didn't seem to take any nickel, even after repeated cleanings with acetone. The other 2 parts didn't take nickel at all I don't think. I then plated with rhodium from a competitor. Seemed to plate ok until I used Simichrome to clean things up. The plating didn't last more than 3 strokes with a rag before it was almost totally gone. The spots that seemed to plate on the 1 part survived much better. The brass is all from the same bar of 260 brass, polished at the same time (night before I plated them) using the same process. I have used the nickel on plain steel and it worked, but have not had success with it on either stainless or brass. Any suggestions? Thanks Scott |
Don't use acetone to clean...use our SP Degreaser.
Simichrome is extremely agressive - use something milder to polish if you need to.
-- Lance Caswell Caswell Inc http://www.caswellplating.com Need Support? Visit our online support section at http://support.caswellplating.com Have A Web Site? Why not join our affiliate program and earn 15% of all sales. Join at http://www.caswellplating.com/affiliate.htm Please support the moderators on our site by leaving reputation for their helpful posts. Read more here. |
| Need production Black oxide and nickel on brass | shuey911 | Services Offered/Wanted | 3 | 01-24-2007 03:49 PM |
| Problem plating Nickel on to Brass | kuma13 | Electroplating Questions | 6 | 05-17-2005 03:54 PM |
| Black Krome PnP over Nickel PnP (brass revolver frame)? | arcom | Electroplating Questions | 0 | 02-01-2005 12:18 PM |
| Electroless Nickel on Brass | Butterfly | Electroplating Questions | 1 | 02-27-2004 03:53 PM |
| removing nickel plating from brass? | thomaconda | Other Metal Finishing Questions | 2 | 02-27-2003 10:36 AM |
