My question is: I want to try the nickel Plug-N-Plate kit. Do you think I could use the dip method? Or should I just stay with the brush stroke technique? I do not intend to buff it out because I'm hoping it will more or less duplicate the existing surface but not require constant upkeep and oiling. If I take it out and it rains, it's a pain. I have re-blued the barrels. Any thoughts? Thanks / Charlie |
Hi Charlie:
Plug N Plate is designed for very small parts. I'm no gun expert, but I imagine the barrels of a double barrelled shotgun to be quite large (over 12" long). These will be impossible to immerse in 8oz of Plug N Plate Nickel Solution, and even too large for the brush method. You'll be best using a 3-4.5 gallon nickel plating kit to immerse these parts in and re-nickel plate. You'll need the kit, and a DC power supply (rectifier or battery). If you want a bright, shiny nickel, you'll need to buff the parts first. If my assumptions from above are incorrect, please let me know.
-- Lance Caswell Caswell Inc http://www.caswellplating.com Need Support? Visit our online support section at http://support.caswellplating.com Have A Web Site? Why not join our affiliate program and earn 15% of all sales. Join at http://www.caswellplating.com/affiliate.htm Please support the moderators on our site by leaving reputation for their helpful posts. Read more here. |
It's only the receiver, not the barrels. The receiver (maybe not the right terminology for a double) is the part that has the trigger, firing pins and springs. It weighs maybe 2 pounds, is 4 inches long not including a tang which does not need plated, 2.5 or so wide, and 2 deep. My plan was to mask all but the exterior surfaces. As close as I can estimate, the total area not masked would be 9-10 square inches at most.
If the dip method is too iffy, I could try the brush technique. I'm just not sure if it's applicable for a big smooth part like this. I don't intend to buff or polish but I was concerned that it might wind up with very apparent streaking and uneven plating unless I dipped it. Thanks again |
| PLATING POT METAL............... | 48Buick | Plating Pot Metal | 35 | 11-10-2009 10:25 PM |
| I found sand blasting aluminum prior to powder coating is a big no-no. | mtumbleson | Powder Coating Questions | 59 | 04-07-2008 08:37 PM |
| Part cleaning. | nil8u | Electroplating Questions | 9 | 08-22-2006 01:23 PM |
| Part is 1/2 blue 4A, 1/2 Deep red. red fades when boiled | frubino | Anodizing Questions | 1 | 07-27-2004 02:56 PM |
| A few question to help a beginner | Cyberave68 | Anodizing Questions | 6 | 06-08-2004 09:53 PM |
