Old 02-19-2007, 12:18 AM
scottmn is on a distinguished road
Default removalable masking agent?
I am electroless nickel plating some knives. The handles are bakelite. I'm sure the bakelite could probably withstand the heat, but I'd rather not take the chance! Is there some special easy to remove masking agent available?
Old 02-19-2007, 12:11 PM
cprocess is an unknown quantity at this point
Default Re: removalable masking agent?
You can use teflon tape or vinyl tape. It must be rated for "high temp" since electroless nickel operates around 190 degrees F. They also market a tape called "platers tape". You can also use a brush-on or spray-on plastisol-type material. If you have holes you want to mask, you can use elastomer plugs.
Masking Agent elgman Electroplating Questions 4 05-15-2007 04:58 PM
Using Masking Agent lbull Plating Pot Metal 1 12-28-2003 02:51 PM
Masking products for EN plating? edclark Electroplating Questions 0 12-23-2003 03:41 PM
Looking for masking tape recomendations. chcarver Metal Polishing Questions 0 03-06-2003 02:51 PM
masking agent for anodizing aluminum john Anodizing Questions 1 09-06-2002 10:20 AM
