I have spent a little time working out the exact surface area of the nuts I used for my tests, although I had thought the were around 3.5", I was not too far away, surface area calulated after measuring all areas with a digital vernier came out at 4.03", that still means that I am having to use way too many amps @ 235Ma per square inch to get the best result -
any furher ideas as to why ? |
At .235 A/sq-in, those parts should be fizzing prodigiously, and burning badly. Have you determined that you've got enough brightener? Sean
Seans Zinc Plating page |
I have been adding brightner at the start of each plating cycle as recommended in the manual, is there a way to test the levels ?
I am almost of of brightner now, so will have to order some more. Can you have too much brightner ? If so what would the effects of this be ? |
Rab:
You do NOT add brightener every time. You add it ONCE, and when parts start to plate less brightly, add a bit more. This may take many plating cycles, it just depends on total sq-inches plated. Quote:
I do NOT know what the consequences would be though. Contact Caswell tech support and ask them. In the meanwhile, if you filter the solution, that should remove most of the brightener. Sean
| copy cad power problems....I think?????? | lintmann | Electroplating Questions | 9 | 10-20-2006 12:39 PM |
| What Power Supply do I use for Copy Chrome | cgworth | Electroplating Questions | 1 | 12-11-2005 05:18 PM |
| anno power supply | jasonboulanger | Anodizing Questions | 2 | 01-07-2005 06:48 PM |
| Anodizing Power Supply Q's | jnbsystems | Anodizing Questions | 7 | 10-02-2003 11:33 PM |
| Copy Cad Power Supply | MDRSSR | Electroplating Questions | 1 | 01-31-2002 08:39 AM |
