Connect with Facebook
Closed Thread
Old 03-03-2003, 02:32 AM
aermakov@rogers.com
Default Yellow Chromate & Copy Cad
Hi. I had the kit for about three weeks now, it is still awesome. Have absolutely no complaints, praise only. However, I was under an impression that Yellow Chromate will dye even commercially obtained zinc plated items. I tried to "yellow" some nuts and bolts from a local hardware store, the color seems to be right, but the yellow finish can be rubbed off with a shop towel (24 hours later)! The items were properly degreased and I tried some battery acid on them, zinc reacted very rapidly. What am I doing wrong? I must note that my freshly plated parts accept Chromate well and finish seems somewhat durable, still VERY easy to remove the yellow coloring with steel wool. My chromate solution is applied for two minutes at 22 deg. Cel. Thanks.
Andrew.
Old 03-03-2003, 10:35 AM
mcaswell's Avatar
Caswell Inc Founder
You might want to try freshening the zinc plate on your store bought parts with the plating kit, then chromating them.
Have A Web Site?
Old 03-03-2003, 12:27 PM
aermakov@rogers.com
That's what I did, will let you know when the parts dry out.
Old 03-03-2003, 07:28 PM
newman
i too am having a hard time getting the yellow chromate to hold, right after i zinc plate i rinse with water and dunk into chromate for about 1-2 mins ,after 2-3 days i can remove all the color off with water and a rag, im running the bath @80%.... any ideas how to resolve this?
would a Nitric Dip help right before chromating?
thanks .
ps: im zinc plating old carb castings from the 60s.
Closed Thread
Copy Cad - Yellow Chromate does not stay on charlton Electroplating Questions 1 07-31-2005 12:52 PM
Chromate for Copy Cad/Zinc - Bright Blue kberger56 Caswell Please Sell This... 0 05-09-2005 12:32 AM
Copy Cad kit - blackener and yellow cad durability problems Broke Electroplating Questions 11 01-09-2005 11:19 AM
Yellow Chromate on Galvanized? Rickc Electroplating Questions 0 01-31-2004 06:19 PM
Copy Cad: Flat items okay; bolts dark? red911 Electroplating Questions 5 11-08-2003 09:17 PM
